简介
The replacement process for this part is very simple. It will only take a few minutes, and you can continue with your day.
你所需要的
Locate the 30 mm bolt and nut attaching the latch to the base.
Use a wrench to remove the nut attached to the bolt, freeing the latch from the base.
即将完成!
结论
