跳转到主内容
Portege Z830-S8302 Internal Cooling Fan Replacement
你所需要的
  1. Portege Z830-S8302 Internal Cooling Fan Replacement, Internal Cooling Fan: 步骤 1 中的图像 1,3 Portege Z830-S8302 Internal Cooling Fan Replacement, Internal Cooling Fan: 步骤 1 中的图像 2,3 Portege Z830-S8302 Internal Cooling Fan Replacement, Internal Cooling Fan: 步骤 1 中的图像 3,3
    • Flip the laptop over, with screen facing down to reveal bottom panel.
    • Remove thirteen 1.4mm Phillips #0 screws around the border of the frame.
  2. Portege Z830-S8302 Internal Cooling Fan Replacement: 步骤 2 中的图像 1,3 Portege Z830-S8302 Internal Cooling Fan Replacement: 步骤 2 中的图像 2,3 Portege Z830-S8302 Internal Cooling Fan Replacement: 步骤 2 中的图像 3,3
    • Using the metal spudger, remove the rubber fitting in middle of back panel to reveal hidden screw.
    • Use a Torx T7 bit screwdriver to remove screw.
  3. Portege Z830-S8302 Internal Cooling Fan Replacement: 步骤 3 中的图像 1,3 Portege Z830-S8302 Internal Cooling Fan Replacement: 步骤 3 中的图像 2,3 Portege Z830-S8302 Internal Cooling Fan Replacement: 步骤 3 中的图像 3,3
    • Remove the SD card in top right hand corner of the device, next to the headphone ports.
    • Push in the SD card then pull out completely to remove from slot.
    • This will help in the removal of backplate.
  4. Portege Z830-S8302 Internal Cooling Fan Replacement: 步骤 4 中的图像 1,2 Portege Z830-S8302 Internal Cooling Fan Replacement: 步骤 4 中的图像 2,2
    • Lift the back plate starting at the opposing edge to the SD card. Lift from left to right and continue lifting this plate at this angle until its free from the laptop.
    • Once the backplate is completely off, this will reveal the inside components of the device.
  5. Portege Z830-S8302 Internal Cooling Fan Replacement: 步骤 5 中的图像 1,3 Portege Z830-S8302 Internal Cooling Fan Replacement: 步骤 5 中的图像 2,3 Portege Z830-S8302 Internal Cooling Fan Replacement: 步骤 5 中的图像 3,3
    • Remove two 5mm Phillips #0 screws from the fan housing.
  6. Portege Z830-S8302 Internal Cooling Fan Replacement: 步骤 6 中的图像 1,2 Portege Z830-S8302 Internal Cooling Fan Replacement: 步骤 6 中的图像 2,2
    • Use the nylon spudger to disconnect the wire (red/blue) plug from the motherboard.
    • Be gentle and do not apply too much pressure when removing the plug as the motherboard may be fragile.
  7. Portege Z830-S8302 Internal Cooling Fan Replacement: 步骤 7 中的图像 1,2 Portege Z830-S8302 Internal Cooling Fan Replacement: 步骤 7 中的图像 2,2
    • Lift up the wire and peel back the clear protective tape.
    • Split the black protective foam inside the tape in half to uncover the wires.
    • This should make the wires free of all connections.
  8. Portege Z830-S8302 Internal Cooling Fan Replacement: 步骤 8 中的图像 1,2 Portege Z830-S8302 Internal Cooling Fan Replacement: 步骤 8 中的图像 2,2
    • The fan is now free and able to be removed. Lift the fan out of place.
结论
Tanner Krygier
于09/17/18注册
913 声望
创作了5篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 20
总计 809
