跳转到主内容
Portege Z830-S8302 Battery Replacement
你所需要的
  1. Portege Z830-S8302 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Portege Z830-S8302 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Portege Z830-S8302 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Flip the laptop over with the screen facing down to reveal the bottom panel.
    • Unscrew each of the highlighted screws with a Phillips #0 screwdriver.
  2. Portege Z830-S8302 Battery Replacement: 步骤 2 中的图像 1,3 Portege Z830-S8302 Battery Replacement: 步骤 2 中的图像 2,3 Portege Z830-S8302 Battery Replacement: 步骤 2 中的图像 3,3
    • Use a metal spudger to remove fitting and reveal the screw.
    • Use a screwdriver with a Torx T7 bit to remove the screw.
  3. Portege Z830-S8302 Battery Replacement: 步骤 3 中的图像 1,3 Portege Z830-S8302 Battery Replacement: 步骤 3 中的图像 2,3 Portege Z830-S8302 Battery Replacement: 步骤 3 中的图像 3,3
    • The SD Card slot is on the top right corner of the device near the headphone jacks.
    • Depress the fake SD Card and release.
    • Pull the fake SD Card out and remove it completely from the slot, as this will help in the removal of the backplate.
  4. Portege Z830-S8302 Battery Replacement: 步骤 4 中的图像 1,2 Portege Z830-S8302 Battery Replacement: 步骤 4 中的图像 2,2
    • Lift the back plate starting at the opposing edge to the SD card. Lift from left to right and continue lifting this plate at this angle until it's free from the laptop.
    • Once the backplate is completely off, this will reveal the inside components of the device.
    • Upon reassembly of the back cover, make sure to line up the two headphone jacks on the upper right corner with the holes in the back cover or else it will not seat fully.
  5. Portege Z830-S8302 Battery Replacement: 步骤 5 中的图像 1,3 Portege Z830-S8302 Battery Replacement: 步骤 5 中的图像 2,3 Portege Z830-S8302 Battery Replacement: 步骤 5 中的图像 3,3
    • The battery is the black rectangular piece in the bottom half of the device.
    • Remove six 5mm screws holding down the battery using a Phillips PH0 screwdriver.
    • Lift the battery and separate from its place holder.
    • Do not fully remove the battery as it is still connected by the connector in the top right corner.
  6. Portege Z830-S8302 Battery Replacement: 步骤 6 中的图像 1,3 Portege Z830-S8302 Battery Replacement: 步骤 6 中的图像 2,3 Portege Z830-S8302 Battery Replacement: 步骤 6 中的图像 3,3
    • Using the nylon spudger, disconnect the white plugin.
    • Once the wire has been disconnected you may remove the battery.
结论
2等其他人完成本指南。
Tanner Krygier
于09/17/18注册
913 声望
创作了5篇指南
团队
一条评论
can we still run it without battery? i mean using direct power supply and no battery install
hairu nizam - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 23
总计 738
