跳转到主内容
Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement
  1. Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Removing the Battery Cover: 步骤 1 中的图像 1,3 Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Removing the Battery Cover: 步骤 1 中的图像 2,3 Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Removing the Battery Cover: 步骤 1 中的图像 3,3
    • Hold the mouthpiece of the handset and locate the lock-unlock text.
    • Twist the battery cover counterclockwise from the "lock" to the "unlock" position.
  2. Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Disconnecting the Battery Wire: 步骤 2 中的图像 1,3 Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Disconnecting the Battery Wire: 步骤 2 中的图像 2,3 Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Disconnecting the Battery Wire: 步骤 2 中的图像 3,3
    • To disconnect the battery pack wire from the phone, squeeze the tab against the connector and pull connector straight up from the socket.
  3. Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Removing the Battery Pack: 步骤 3 中的图像 1,3 Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Removing the Battery Pack: 步骤 3 中的图像 2,3 Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Removing the Battery Pack: 步骤 3 中的图像 3,3
    • Pull the battery from the battery compartment.
    • You may need to gently wiggle the battery back and forth in its compartment to help loosen it.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 909
