跳转到主内容
Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement
你所需要的
  1. Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement, Removing the Antenna Screw: 步骤 1 中的图像 1,3 Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement, Removing the Antenna Screw: 步骤 1 中的图像 2,3 Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement, Removing the Antenna Screw: 步骤 1 中的图像 3,3
    • Inside the base cover, locate the screw holding the antenna in place and use a Philips #00 screwdriver to remove the 6mm screw.
  2. Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement, Removing the Antenna Foot: 步骤 2 中的图像 1,2 Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement, Removing the Antenna Foot: 步骤 2 中的图像 2,2
    • Grasp the plastic antenna foot and pull toward you.
  3. Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement, Removing the Antenna: 步骤 3 中的图像 1,2 Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement, Removing the Antenna: 步骤 3 中的图像 2,2
    • Pull antenna from the top side of the phone base cover.
    • It helps if you gently wiggle the antenna back and forth to loosen the clips.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 349
