跳转到主内容
Polycom SoundStation Back Housing Replacement
你所需要的
  1. Polycom SoundStation Back Housing Replacement, Back Housing: 步骤 1 中的图像 1,1
    • Flip the device over. Using a Phillips #00 screwdriver, remove the black 10mm screw on each three legs of the phone.
    • Using a Phillips #00 screwdriver, remove the two silver 7mm screws as pictured.
  2. Polycom SoundStation Back Housing Replacement: 步骤 2 中的图像 1,2 Polycom SoundStation Back Housing Replacement: 步骤 2 中的图像 2,2
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing off!
结论
团队
一条评论
thanks for this - the 7mm were under footpads so I couldn’t see them. cover now off, keyboard dried of coffee and working fine again!!
J M - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 1,182
