跳转到主内容
Polk MagniFi Soundbar Bluetooth Cable Replacement
你所需要的
  1. Polk MagniFi Soundbar Bluetooth Cable Replacement, Bluetooth Cable: 步骤 1 中的图像 1,3 Polk MagniFi Soundbar Bluetooth Cable Replacement, Bluetooth Cable: 步骤 1 中的图像 2,3 Polk MagniFi Soundbar Bluetooth Cable Replacement, Bluetooth Cable: 步骤 1 中的图像 3,3
    • To reveal the control button, first, carefully remove the front cover of the Sound Bar.
    • Use the plastic iFixit opening tool to lift up the front surface. Insert the tool between the cover and the body to open it.
    • After the cover is fully removed, it will be able to see the interior speaker.
    • Carefully unscrew all 16 screws to release the panel.
    • There are total 16 screws that secures the panel onto the cover. Each screw is approximately 1.50 centimeter.
  2. Polk MagniFi Soundbar Bluetooth Cable Replacement: 步骤 2 中的图像 1,3 Polk MagniFi Soundbar Bluetooth Cable Replacement: 步骤 2 中的图像 2,3 Polk MagniFi Soundbar Bluetooth Cable Replacement: 步骤 2 中的图像 3,3
    • To remove the cover behind the control buttons, insert the iFixit opening tool between the cover and the body
    • Push the opening tool along the edge of the cover to fully open it.
  3. Polk MagniFi Soundbar Bluetooth Cable Replacement: 步骤 3 中的图像 1,1
    • Underneath the cover, there is a black panel screwed onto the cover with two sets of wires plugged into it.
  4. Polk MagniFi Soundbar Bluetooth Cable Replacement: 步骤 4 中的图像 1,2 Polk MagniFi Soundbar Bluetooth Cable Replacement: 步骤 4 中的图像 2,2
    • Grasp the wire firmly close to the base and pull straight out. Repeat this for the other end of the wire.
    • This wire is easily broken. Handle with care.
结论
[deleted]
于10/22/18注册
671 声望
创作了4篇指南
一条评论
Can you pair it with Beats headphones.?
wayne rivers - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 24
总计 2,368
