跳转到主内容
Polaroid i533 LCD Screen Replacement
你所需要的
  1. Polaroid i533 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,3 Polaroid i533 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 2,3 Polaroid i533 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 3,3
    • Remove the four 3mm screws from the left-hand side of the camera screen.
    • On the right-hand side of the camera screen, unscrew and remove the two 3mm screws.
    • On the bottom of the camera, unscrew and remove the three 3mm screws.
  2. Polaroid i533 LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Slide the battery door open and slightly open the side of the case with a plastic opening tool.
  3. Polaroid i533 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Be careful not to pull the cover off completely, as it should remain attached to the motherboard.
    • Gently pull the cover away from the rest of the camera. Do not separate the pieces completely.
  4. Polaroid i533 LCD Screen Replacement: 步骤 4 中的图像 1,2 Polaroid i533 LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Locate where the LCD screen ribbon is attached to the logic board.
    • Using the iFixit plastic opening tool, flip up the black tab that connects the LCD screen ribbon to the motherboard.
  5. Polaroid i533 LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Gently pull the ribbon away from the motherboard. This will allow the cover to separate from the rest of the camera.
  6. Polaroid i533 LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Locate the four screws in each corner of the LCD screen and carefully remove them. After they have been removed, ensure the screws stay separate from the 3mm case screws.
  7. Polaroid i533 LCD Screen Replacement: 步骤 7 中的图像 1,1
    • Remove the LCD screen from the remaining casing of the camera.
结论
另外一个人完成了本指南。
ashley
于06/24/10注册
19 声望
撰写一个指南
团队
Cal Poly, Team 3-4, Johann Summer 2010 Cal Poly, Team 3-4, Johann Summer 2010 的会员
CPSU-JOHANN-R10S3G4
4 名成员
创作了9篇指南
1指南评论
great job and information
John Webb - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 10
总计 3,912
