跳转到主内容
Polaroid Z2300 Battery Replacement
  1. Polaroid Z2300 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Polaroid Z2300 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the camera upside down and gently use your thumb to pull the hatch forward and then upwards.
    • Once you lift the hatch up you will see the battery.
  2. Polaroid Z2300 Battery Replacement: 步骤 2 中的图像 1,2 Polaroid Z2300 Battery Replacement: 步骤 2 中的图像 2,2
    • Once you see the battery, you will see a tab saying 'pull' attached to the battery. gently pull on it until the battery is removed from the camera.
    • You can pull the battery easily afterwards.
  3. Polaroid Z2300 Battery Replacement: 步骤 3 中的图像 1,1
    • Afterwards, you can easily reattach the battery back.
结论
Jasem Almeeli
于03/02/17注册
101 声望
撰写一个指南
团队
USF Tampa, Team S13-G1, Cagle Spring 2017 USF Tampa, Team S13-G1, Cagle Spring 2017 的会员
USFT-CAGLE-S17S13G1
4 名成员
创作了2篇指南
一条评论
Do you know where to find a replacement battery? I’ve looked all over the internet.
Wendy Ralph - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 50
总计 3,771
