当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Move film door slide on the left side of camera forward.
Pull film door open.
Open the flash assembly by holding the sides of the top piece of the camera and pushing up gently until it snaps into place.
If your camera is old or dirty, it may take more force to open the flash assembly.
Use a spudger on each side to separate the flash segment from the main body.
Be careful not to do this too hard because you may pull out the connecting wires.
Use several plastic opening tools around the edges of the camera's body to separate it from the plastic frame.
Place left hand on the gray section and right hand on the black section.
Pull the sections apart.
Carefully remove the damaged lens from the interior of the camera.
Replace with a new lens.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与5其他贡献者
于01/20/10注册
357 声望
撰写一个指南
徽章: 9
+ 6更多徽章
CPSU-MANESS-W10S3G18
4 名成员
创作了4篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 6
过去 7 天: 12
过去 30 天: 60
总计 10,595
