跳转到主内容
Polaroid Sun 600 LMS Film Pack Replacement
  1. Polaroid Sun 600 LMS Film Pack Replacement, Film Pack: 步骤 1 中的图像 1,1
    • Locate film door and slide release latch.
    • The slide release is near the lower left corner towards the front of the camera.
  2. Polaroid Sun 600 LMS Film Pack Replacement: 步骤 2 中的图像 1,1
    • Slide side latch towards the front of camera.
    • The film door will pop open.
  3. Polaroid Sun 600 LMS Film Pack Replacement: 步骤 3 中的图像 1,1
    • Insert film pack.
    • Make sure the battery contacts on the film pack are facing down and in contact with the camera's contacts.
  4. Polaroid Sun 600 LMS Film Pack Replacement: 步骤 4 中的图像 1,1
    • Close film door by gently pushing it back into place.
终点
另外一个人完成了本指南。
Matthew Lessig
于01/20/10注册
63 声望
创作了3篇指南
团队
Cal Poly, Team 3-18, Maness Winter 2010 Cal Poly, Team 3-18, Maness Winter 2010 的会员
CPSU-MANESS-W10S3G18
4 名成员
创作了4篇指南
3条评论
Where would you buy the sun 600 LMS battery film?
Albert Einstein - 回复
Where can I buy Sun 600 LMS instant battery film?
How do you fix the flash
Edward Flores - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 22
总计 12,136
