跳转到主内容
Polaroid SNAP View Finder Replacement
你所需要的
  1. Polaroid SNAP View Finder Replacement, Polaroid SNAP Front and Back Face Plate Removal: 步骤 1 中的图像 1,1
    • Open the paper door of the camera, then locate and remove the screws that are on the top and bottom edge of the inside of the camera.
    • Screw head: Phillips, Screw length: 3mm
  2. Polaroid SNAP View Finder Replacement: 步骤 2 中的图像 1,2 Polaroid SNAP View Finder Replacement: 步骤 2 中的图像 2,2
    • Push the rear face plate from the short side nearest the screws you just removed towards the other short side of the camera. It should slide forward and unlock the clips holding it in place.
    • Then it should be easy to simply lift the rear face plate up and remove it.
  3. Polaroid SNAP View Finder Replacement: 步骤 3 中的图像 1,2 Polaroid SNAP View Finder Replacement: 步骤 3 中的图像 2,2
    • Locate and remove the four screws on the corners of the camera, they're quite small and may be difficult to remove.
    • Screw head: Philips, Screw length: 5mm
  4. Polaroid SNAP View Finder Replacement: 步骤 4 中的图像 1,3 Polaroid SNAP View Finder Replacement: 步骤 4 中的图像 2,3 Polaroid SNAP View Finder Replacement: 步骤 4 中的图像 3,3
    • Once the screws are removed, flip the camera over
    • Use a plastic opening tool to disengage the six clips until the front face plate can be removed safely
  5. Polaroid SNAP View Finder Replacement: 步骤 5 中的图像 1,1
    • The cameras innards should now be accessible to you
  6. Polaroid SNAP View Finder Replacement, View Finder: 步骤 6 中的图像 1,2 Polaroid SNAP View Finder Replacement, View Finder: 步骤 6 中的图像 2,2
    • Gently grasp the view finder (while in the closed position) with your thumb and fore finger. Then carefully pull the viewfinder outwards.
  7. Polaroid SNAP View Finder Replacement: 步骤 7 中的图像 1,2 Polaroid SNAP View Finder Replacement: 步骤 7 中的图像 2,2
    • Once the view finder is out, a small black tab should come loose from the viewfinder. Insert this small black tab in to the hole on the side of the new view finder, with the round side up.
结论
2等其他人完成本指南。
Austin Broyles
于02/09/16注册
249 声望
创作了2篇指南
团队
USF Tampa, Team 7-3, Cheng Spring 2016 USF Tampa, Team 7-3, Cheng Spring 2016 的会员
USFT-CHENG-S16S7G3
4 名成员
创作了19篇指南
1指南评论
Where can I buy a replacement viewfinder for this camera?
Shelby Sisk - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 25
总计 3,846
