跳转到主内容
Polaroid SNAP Shutter Button Replacement
你所需要的
  1. Polaroid SNAP Shutter Button Replacement, Polaroid SNAP Front and Back Face Plate Removal: 步骤 1 中的图像 1,1
    • Open the paper door of the camera, then locate and remove the screws that are on the top and bottom edge of the inside of the camera.
    • Screw head: Phillips, Screw length: 3mm
  2. Polaroid SNAP Shutter Button Replacement: 步骤 2 中的图像 1,2 Polaroid SNAP Shutter Button Replacement: 步骤 2 中的图像 2,2
    • Push the rear face plate from the short side nearest the screws you just removed towards the other short side of the camera. It should slide forward and unlock the clips holding it in place.
    • Then it should be easy to simply lift the rear face plate up and remove it.
  3. Polaroid SNAP Shutter Button Replacement: 步骤 3 中的图像 1,2 Polaroid SNAP Shutter Button Replacement: 步骤 3 中的图像 2,2
    • Locate and remove the four screws on the corners of the camera, they're quite small and may be difficult to remove.
    • Screw head: Philips, Screw length: 5mm
  4. Polaroid SNAP Shutter Button Replacement: 步骤 4 中的图像 1,3 Polaroid SNAP Shutter Button Replacement: 步骤 4 中的图像 2,3 Polaroid SNAP Shutter Button Replacement: 步骤 4 中的图像 3,3
    • Once the screws are removed, flip the camera over
    • Use a plastic opening tool to disengage the six clips until the front face plate can be removed safely
  5. Polaroid SNAP Shutter Button Replacement: 步骤 5 中的图像 1,1
    • The cameras innards should now be accessible to you
  6. Polaroid SNAP Shutter Button Replacement, Shutter Button: 步骤 6 中的图像 1,1
    • Look at the top left corner of the camera. This is where the shutter button is located.
  7. Polaroid SNAP Shutter Button Replacement: 步骤 7 中的图像 1,2 Polaroid SNAP Shutter Button Replacement: 步骤 7 中的图像 2,2
    • Using the nylon spudger, locate the red tips under the shutter button.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Gently push on the shutter button tabs upwards, until the tab is dislodged. Repeat same steps for other two tabs.
  8. Polaroid SNAP Shutter Button Replacement: 步骤 8 中的图像 1,2 Polaroid SNAP Shutter Button Replacement: 步骤 8 中的图像 2,2
    • Once shutter button has dislodged from underneath. Gently use your fingers to pull out the button, careful there is a spring underneath the button
结论
2等其他人完成本指南。
团队
USF Tampa, Team 7-3, Cheng Spring 2016 USF Tampa, Team 7-3, Cheng Spring 2016 的会员
USFT-CHENG-S16S7G3
4 名成员
创作了19篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 26
总计 3,995
