跳转到主内容
Polaroid SNAP Battery Replacement
你所需要的
  1. Polaroid SNAP Battery Replacement, Polaroid SNAP Front and Back Face Plate Removal: 步骤 1 中的图像 1,1
    • Open the paper door of the camera, then locate and remove the screws that are on the top and bottom edge of the inside of the camera.
    • Screw head: Phillips, Screw length: 3mm
  2. Polaroid SNAP Battery Replacement: 步骤 2 中的图像 1,2 Polaroid SNAP Battery Replacement: 步骤 2 中的图像 2,2
    • Push the rear face plate from the short side nearest the screws you just removed towards the other short side of the camera. It should slide forward and unlock the clips holding it in place.
    • Then it should be easy to simply lift the rear face plate up and remove it.
  3. Polaroid SNAP Battery Replacement: 步骤 3 中的图像 1,2 Polaroid SNAP Battery Replacement: 步骤 3 中的图像 2,2
    • Locate and remove the four screws on the corners of the camera, they're quite small and may be difficult to remove.
    • Screw head: Philips, Screw length: 5mm
  4. Polaroid SNAP Battery Replacement: 步骤 4 中的图像 1,3 Polaroid SNAP Battery Replacement: 步骤 4 中的图像 2,3 Polaroid SNAP Battery Replacement: 步骤 4 中的图像 3,3
    • Once the screws are removed, flip the camera over
    • Use a plastic opening tool to disengage the six clips until the front face plate can be removed safely
  5. Polaroid SNAP Battery Replacement: 步骤 5 中的图像 1,1
    • The cameras innards should now be accessible to you
  6. Polaroid SNAP Battery Replacement, Battery: 步骤 6 中的图像 1,1
    • Two foam strips and adhesive glue binds the battery to the camera.
  7. Polaroid SNAP Battery Replacement: 步骤 7 中的图像 1,1
    • Remove the battery by lifting up the battery from the left corner. If you can not remove the battery with your hands, consider using a Plastic Opening Tool
  8. Polaroid SNAP Battery Replacement: 步骤 8 中的图像 1,2 Polaroid SNAP Battery Replacement: 步骤 8 中的图像 2,2
    • Using your fingers, remove the five pin connector from the device.
结论
15等其他人完成本指南。
Ian Colantuoni
于02/09/16注册
619 声望
创作了2篇指南
团队
USF Tampa, Team 7-3, Cheng Spring 2016 USF Tampa, Team 7-3, Cheng Spring 2016 的会员
USFT-CHENG-S16S7G3
4 名成员
创作了19篇指南
24指南评论
Thank you so much for showing me how to do this. FYI: For the digital LCD screen version of this camera, there is only one screw to take out on that first step.
Can you tell me where I can buy the replacement battery for this camera? Thanks.
Tommy Li - 回复
I would like to know where to buy it too.
Giorgina Nardi - 回复
Same question need to know where to purchase a new battery and is this a common issue for the snap touch
Anita Guzman - 回复
I also need a battery and it seems almost impossible to find one to buy. Please let me know if anybody has found a replacement battery that fits.
Jaco Botha - 回复
Has anyone managed to find where to buy a replacement battery?
ajm.smith - 回复
添加评论
浏览统计数据:
过去 24 小时: 37
过去 7 天: 171
过去 30 天: 688
总计 76,354
