跳转到主内容
Polaroid S7 Digitizer Replacement
你所需要的
  1. Polaroid S7 Digitizer Replacement, Remove the back: 步骤 1 中的图像 1,2 Polaroid S7 Digitizer Replacement, Remove the back: 步骤 1 中的图像 2,2
    • Insert the flat end of one of the plastic opening tools between the screen and the colored back cover. Gently pry apart the pieces.
    • Carefully separate the screen from the back, taking care not to rip the ribbons connecting them.
  2. Polaroid S7 Digitizer Replacement: 步骤 2 中的图像 1,2 Polaroid S7 Digitizer Replacement: 步骤 2 中的图像 2,2
    • Insert the plastic opening tool into the wedge and pry it open.
  3. Polaroid S7 Digitizer Replacement: 步骤 3 中的图像 1,1
    • Open the latch and pull to remove the LCD.
  4. Polaroid S7 Digitizer Replacement, Digitizer: 步骤 4 中的图像 1,1
    • After you remove the digitizer, open the latch and remove the screen.
  5. Polaroid S7 Digitizer Replacement: 步骤 5 中的图像 1,1
    • To install the new screen, insert the digitizer into the new screen and latch them back in.
结论
Thiago Guedes
于01/20/15注册
17 声望
创作了2篇指南
团队
USF Tampa, Team 1-2, Blackwell Winter 2015 USF Tampa, Team 1-2, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S1G2
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 179
