跳转到主内容
Polaroid S7 Battery Replacement
你所需要的
  1. Polaroid S7 Battery Replacement, Remove the back: 步骤 1 中的图像 1,2 Polaroid S7 Battery Replacement, Remove the back: 步骤 1 中的图像 2,2
    • Insert the flat end of a soft plastic opening tool between the screen and the back cover.
    • Pry the two pieces apart.
    • Take care not to rip the ribbons that connect the screen to the back cover.
  2. Polaroid S7 Battery Replacement: 步骤 2 中的图像 1,1
    • Use a metal spudger to remove the orange sticker.
  3. Polaroid S7 Battery Replacement: 步骤 3 中的图像 1,1
    • Use the screwdriver to remove the 2 x 4 mm Phillips #00 head screws from the blue board located on the lower-right corner of the battery.
  4. Polaroid S7 Battery Replacement: 步骤 4 中的图像 1,2 Polaroid S7 Battery Replacement: 步骤 4 中的图像 2,2
    • Use the metal spudger to remove the three pieces of clear tape adhering from the battery to the blue board.
    • Pry the battery up from the right side.
  5. Polaroid S7 Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the yellow plastic that covers the battery connector.
  6. Polaroid S7 Battery Replacement: 步骤 6 中的图像 1,1
    • Use a soldering iron to remove the wires connected to the battery.
结论
团队
USF Tampa, Team 1-2, Blackwell Winter 2015 USF Tampa, Team 1-2, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S1G2
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 3,249
