跳转到主内容
Polaroid S10 volume button Replacement
你所需要的
  1. Polaroid S10 volume button Replacement, Removing the backcover: 步骤 1 中的图像 1,3 Polaroid S10 volume button Replacement, Removing the backcover: 步骤 1 中的图像 2,3 Polaroid S10 volume button Replacement, Removing the backcover: 步骤 1 中的图像 3,3
    • Place an opening pick between the volume button and the back cover.
    • More than one pick may be needed, but avoid placing more than two picks in the same space.
    • Excessive force on the pick will break the volume button.
    • Carefully remove the back cover using the metal spudger.
    • It is normal to hear a snapping noise due to the plastic tabs on the back cover.
  2. Polaroid S10 volume button Replacement, Volume and Power Button Board: 步骤 2 中的图像 1,2 Polaroid S10 volume button Replacement, Volume and Power Button Board: 步骤 2 中的图像 2,2
    • Use the spudger to remove the tape.
    • Remove the 2 J000 4 mm screws using a J000 screwdriver.
    • Carefully disconnect the connector port.
结论
另外一个人完成了本指南。
James
于03/16/15注册
367 声望
创作了3篇指南
团队
Colorado Springs, Team 1-4, May Spring 2015 Colorado Springs, Team 1-4, May Spring 2015 的会员
UCCS-MAY-S15S1G4
4 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 332
