你所需要的
Place an opening pick between the volume button and the back cover.
Carefully remove the back cover using the metal spudger.
Use the spudger to remove the tape.
Remove the 2 J000 4 mm screws using a J000 screwdriver.
Carefully disconnect the connector port.
即将完成!
结论
另外一个人完成了本指南。
