你所需要的
Place an opening pick between the volume button and the back cover.
Carefully remove the back cover using the metal spudger.
Use a spudger to carefully remove the tape nearest to the battery.
Gently use the spudger to remove the battery out of place by wedging it out from the bottom.
Carefully desolder the 2 wires that connect the battery to the motherboard.
即将完成!
结论
