跳转到主内容
加入维修社区 - 创建账户
Polaroid PTAB7XC USB Port Replacement
你所需要的
    1. Polaroid PTAB7XC USB Port Replacement, USB Port: 步骤 1 中的图像 1,2 Polaroid PTAB7XC USB Port Replacement, USB Port: 步骤 1 中的图像 2,2
      • Remove the two 7 mm screws on the top of the device using a J00 Phillips screwdriver, turning the screws counterclockwise.
      • If the screw heads have corroded or been stripped, it may be necessary to use a larger screwdriver head, such as the J0.
      询问修复机器人
      添加评论
    2. Polaroid PTAB7XC USB Port Replacement: 步骤 2 中的图像 1,2 Polaroid PTAB7XC USB Port Replacement: 步骤 2 中的图像 2,2
      • Pry the seam between the screen and the case on all four sides with a large plastic opening tool until the plastic case comes off.
      • Lift the device off of the case and flip over the device so that it sits screen side down.
      • The device is now free from the plastic casing.
      • The power and/or volume buttons may fall out at this point. There is no problem with this; however, be sure to remember to reinstall them when reassembling the device.
      询问修复机器人
      添加评论
    3. Polaroid PTAB7XC USB Port Replacement: 步骤 3 中的图像 1,3 Polaroid PTAB7XC USB Port Replacement: 步骤 3 中的图像 2,3 Polaroid PTAB7XC USB Port Replacement: 步骤 3 中的图像 3,3
      在这个步骤中使用的工具:
      • Desolder the following components from the motherboard.
      • Desolder from the motherboard the red wire that connects to the speaker unit.
      • Desolder from the motherboard the black wire that connects to the speaker unit.
      • Desolder from the motherboard the gray wire that runs along the edge of the device.
      • Desolder from the motherboard the red wire that connects to the battery unit.
      • Desolder from the motherboard the black wire that connects to the battery unit.
      • The motherboard will now be detached from any wires connecting to the device.
      • If any of the wires do not detach completely during the desoldering process, then gently pull them off using tweezers.
      询问修复机器人
      添加评论
    4. Polaroid PTAB7XC USB Port Replacement: 步骤 4 中的图像 1,3 Polaroid PTAB7XC USB Port Replacement: 步骤 4 中的图像 2,3 Polaroid PTAB7XC USB Port Replacement: 步骤 4 中的图像 3,3
      • Use tweezers to unstick the medium width yellow ribbon cable from the motherboard.
      • Use a small plastic opening tool to slide the two small black holding clips off of the white connector to which the medium width yellow ribbon cable is attached.
      • Use your fingers to gently pull the medium width yellow ribbon cable out of the white connector.
      • Repeat the last two actions to disconnect the narrower yellow ribbon cable and the wider yellow ribbon cable from the motherboard.
      • The motherboard and battery will now be detached from any ribbon cables connecting to the device.
      询问修复机器人
      添加评论
    5. Polaroid PTAB7XC USB Port Replacement: 步骤 5 中的图像 1,3 Polaroid PTAB7XC USB Port Replacement: 步骤 5 中的图像 2,3 Polaroid PTAB7XC USB Port Replacement: 步骤 5 中的图像 3,3
      • Use the PH000 screwdriver remove the four 5 mm screws along the bottom edge of the motherboard, turning the screws counterclockwise.
      • The motherboard is now detached from the device.
      询问修复机器人
      添加评论
    6. Polaroid PTAB7XC USB Port Replacement: 步骤 6 中的图像 1,1
      • Lift the motherboard out of the device using your hands.
      • Set the motherboard down on a heat safe surface so that the gray side of the motherboard is face up.
      询问修复机器人
      添加评论
    7. Polaroid PTAB7XC USB Port Replacement: 步骤 7 中的图像 1,1
      • Desolder each side of the USB port where it is attached to the motherboard.
      • The USB port will now be loosened from the motherboard.
      询问修复机器人
      添加评论
    8. Polaroid PTAB7XC USB Port Replacement: 步骤 8 中的图像 1,1
      • Using tweezers, pull the USB port straight out from the motherboard without wiggling it up, down, or side to side.
      • Wiggling the port may break the small connectors that remain attached to the motherboard.
      • The USB port is now replaceable.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 27
过去 30 天: 45
总计 695
