跳转到主内容
加入维修社区 - 创建账户
Polaroid PTAB7XC Power Button Replacement
你所需要的
    1. Polaroid PTAB7XC Power Button Replacement, Power Button: 步骤 1 中的图像 1,2 Polaroid PTAB7XC Power Button Replacement, Power Button: 步骤 1 中的图像 2,2
      • Remove the two 7 mm screws on the top of the device using a J00 Phillips screwdriver by turning them counterclockwise.
      • If the screw heads have corroded or been stripped, it may be necessary to use a larger screwdriver head, such as the J0.
      询问修复机器人
      添加评论
    2. Polaroid PTAB7XC Power Button Replacement: 步骤 2 中的图像 1,2 Polaroid PTAB7XC Power Button Replacement: 步骤 2 中的图像 2,2
      • Pry the seam between the screen and the case on all four sides with a large plastic opening tool until the plastic case comes off.
      • The plastic case is now free from the device.
      • The plastic power button may or may not fall out at this point. There is no problem if it does.
      询问修复机器人
      添加评论
    3. Polaroid PTAB7XC Power Button Replacement: 步骤 3 中的图像 1,1
      在这个步骤中使用的工具:
      • Use tweezers to push on the side of the black plastic power button that is outside of the device case until the button is as far in as possible.
      • Pull on the part of the broken power button that is exposed on the inside of the device case using tweezers until the button itself comes loose of the case.
      • The power button is now replaceable.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 25
总计 1,180
