简介
This process requires soldering and lots of smelly adhesive. For more information about soldering, take a look at this guide. Be careful, as a ruptured battery can be dangerous.
你所需要的
Remove the two 7 mm screws on the top of the device using a J00 Phillips screwdriver, turning them counterclockwise.
在这个步骤中使用的工具:Plastic Cards$2.99
Wedge a plastic card beneath the battery unit.
Wiggle the card side to side and up and down gently until the glue sealing the battery to the device is broken.
4等其他人完成本指南。
一条评论
This tablet has the exact same setup as the 2011-2012 nextbook part might be interchangeable with this tablet .
