简介
If your device has poor sound quality, follow this guide to remove the speaker.
你所需要的
Pry the seam between the screen and the case and slide it on all four sides with a large plastic opening tool until the plastic case comes off.
在这个步骤中使用的工具:Plastic Cards$2.99
Wedge a plastic card beneath the battery unit and wiggle the card side to side and up and down gently until the glue sealing the battery to the device is broken.
Remove the two 5mm screws attached to the top right and bottom left corners of the speaker
即将完成!
结论
