简介
The charging port is the component that you plug the charger into. It allows the battery to get charged and provides electricity for the device. Since replacing this part can cause damage to other part of the device if the soldering isn't properly done, one needs to be careful when soldering.
你所需要的
Using the PH00 screwdriver, remove the two 4mm screws located on both the left and right sides of the charging port on the bottom of the tablet.
Using the plastic opening tool, insert it into the crease where the glass screen meets the housing of the rest of the tablet. Once inserted, keep inserted and run along the edges to separate the plastic clips from each other to dislodge the back plastic away from the glass and internal components.
