跳转到主内容
Polaroid P902 Charging Port Replacement
你所需要的
  1. Polaroid P902 Charging Port Replacement, Charging Port: 步骤 1 中的图像 1,1
    • Using the PH00 screwdriver, remove the two 4mm screws located on both the left and right sides of the charging port on the bottom of the tablet.
  2. Polaroid P902 Charging Port Replacement: 步骤 2 中的图像 1,1
    • Using the plastic opening tool, insert it into the crease where the glass screen meets the housing of the rest of the tablet. Once inserted, keep inserted and run along the edges to separate the plastic clips from each other to dislodge the back plastic away from the glass and internal components.
  3. Polaroid P902 Charging Port Replacement: 步骤 3 中的图像 1,1
    • Using the PH00 screwdriver, unscrew the four 4.4 mm screws that are anchoring the circuit board down to the rest of the tablet.
  4. Polaroid P902 Charging Port Replacement: 步骤 4 中的图像 1,1
    • Using your fingernail, gently lift up the connectors on the two tabs that are holding the ribbons in place to the circuit board.
    • Be careful when pulling out or reconnecting the ribbons, since if the ribbon or connectors break, they are hard to fix.
  5. Polaroid P902 Charging Port Replacement: 步骤 5 中的图像 1,3 Polaroid P902 Charging Port Replacement: 步骤 5 中的图像 2,3 Polaroid P902 Charging Port Replacement: 步骤 5 中的图像 3,3
    • Using a soldering iron, desolder the points circled on the picture until the solder has liquefied enough to be able to remove the wires from the circuit board.
    • When using the soldering iron, be careful not to cause damage to the motherboard.
  6. Polaroid P902 Charging Port Replacement: 步骤 6 中的图像 1,2 Polaroid P902 Charging Port Replacement: 步骤 6 中的图像 2,2
    • Place the tip of the soldering iron on the four points circled in the image long enough to liquefy the surrounding solder.
  7. Polaroid P902 Charging Port Replacement: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using tweezers, remove the charging port from the circuit board.
    • This should be done quickly as the solder will begin to solidify.
结论
Trent Moskwinski
于03/26/18注册
145 声望
撰写一个指南
团队
IUPUI, Team S2-G2, Harley Spring 2018 IUPUI, Team S2-G2, Harley Spring 2018 的会员
IUPUI-HARLEY-S18S2G2
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 734
