跳转到主内容
Polaroid Onestep Close Up Shutter Switch Replacement
你所需要的
  1. Polaroid Onestep Close Up Shutter Switch Replacement, Flash Assembly Removal: 步骤 1 中的图像 1,3 Polaroid Onestep Close Up Shutter Switch Replacement, Flash Assembly Removal: 步骤 1 中的图像 2,3 Polaroid Onestep Close Up Shutter Switch Replacement, Flash Assembly Removal: 步骤 1 中的图像 3,3
    • Begin by opening the top of the camera (flash assembly) to a slight angle.
    • Next, angle the flash assembly slightly upward and pry off the connections carefully.
    • Be careful not to damage the ribbon cable. This is essential to the operation of the flash.
  2. Polaroid Onestep Close Up Shutter Switch Replacement, Opening Film Tray: 步骤 2 中的图像 1,2 Polaroid Onestep Close Up Shutter Switch Replacement, Opening Film Tray: 步骤 2 中的图像 2,2
    • Slide the action button, on the bottom of the camera, to open the bottom.
  3. Polaroid Onestep Close Up Shutter Switch Replacement, Removing Face Plate: 步骤 3 中的图像 1,3 Polaroid Onestep Close Up Shutter Switch Replacement, Removing Face Plate: 步骤 3 中的图像 2,3 Polaroid Onestep Close Up Shutter Switch Replacement, Removing Face Plate: 步骤 3 中的图像 3,3
    • Insert the blue plastic opening tool between the rear case and the plastic tabs directly under the shelf, and pry it loose.
    • Pull off the face plate.
  4. Polaroid Onestep Close Up Shutter Switch Replacement, Shutter Switch Removal: 步骤 4 中的图像 1,3 Polaroid Onestep Close Up Shutter Switch Replacement, Shutter Switch Removal: 步骤 4 中的图像 2,3 Polaroid Onestep Close Up Shutter Switch Replacement, Shutter Switch Removal: 步骤 4 中的图像 3,3
    • After the face plate is off, the shutter switch should slide out easily.
结论
3等其他人完成本指南。
Tyler OBrien
于09/22/14注册
627 声望
创作了2篇指南
团队
USF Tampa, Team 3-5, Brown Fall 2014 USF Tampa, Team 3-5, Brown Fall 2014 的会员
USFT-BROWN-F14S3G5
3 名成员
创作了6篇指南
2条评论
where did you get the replacement parts for this?
Jacob Sokolove - 回复
I’d love to find a new shutter piece..
Joni Korkkula - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 25
总计 3,916
