跳转到主内容
Polaroid Onestep Close Up Primary Lens Replacement
你所需要的
  1. Polaroid Onestep Close Up Primary Lens Replacement, Flash Assembly Removal: 步骤 1 中的图像 1,3 Polaroid Onestep Close Up Primary Lens Replacement, Flash Assembly Removal: 步骤 1 中的图像 2,3 Polaroid Onestep Close Up Primary Lens Replacement, Flash Assembly Removal: 步骤 1 中的图像 3,3
    • Begin by opening the top of the camera (flash assembly) to a slight angle.
    • Next, angle the flash assembly slightly upward and pry off the connections carefully.
    • Be careful not to damage the ribbon cable. This is essential to the operation of the flash.
  2. Polaroid Onestep Close Up Primary Lens Replacement, Opening Film Tray: 步骤 2 中的图像 1,2 Polaroid Onestep Close Up Primary Lens Replacement, Opening Film Tray: 步骤 2 中的图像 2,2
    • Slide the action button, on the bottom of the camera, to open the bottom.
  3. Polaroid Onestep Close Up Primary Lens Replacement, Removing Face Plate: 步骤 3 中的图像 1,3 Polaroid Onestep Close Up Primary Lens Replacement, Removing Face Plate: 步骤 3 中的图像 2,3 Polaroid Onestep Close Up Primary Lens Replacement, Removing Face Plate: 步骤 3 中的图像 3,3
    • Insert the blue plastic opening tool between the rear case and the plastic tabs directly under the shelf, and pry it loose.
    • Pull off the face plate.
  4. Polaroid Onestep Close Up Primary Lens Replacement, Primary Lens: 步骤 4 中的图像 1,1
    • Once the front assembly is removed, the primary lens should be exposed without any trouble.
  5. Polaroid Onestep Close Up Primary Lens Replacement, Removal of primary lens: 步骤 5 中的图像 1,2 Polaroid Onestep Close Up Primary Lens Replacement, Removal of primary lens: 步骤 5 中的图像 2,2
    • Use your spudger to leverage the lens from the groove at the top (red).
    • Pry the lens loose. It may pop out, so have a method in place to prevent it from dropping.
结论
3等其他人完成本指南。
团队
USF Tampa, Team 3-5, Brown Fall 2014 USF Tampa, Team 3-5, Brown Fall 2014 的会员
USFT-BROWN-F14S3G5
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 15
总计 1,712
