跳转到主内容
Polaroid Onestep Close Up Forward Viewfinder Replacement
你所需要的
  1. Polaroid Onestep Close Up Forward Viewfinder Replacement, Flash Assembly Removal: 步骤 1 中的图像 1,3 Polaroid Onestep Close Up Forward Viewfinder Replacement, Flash Assembly Removal: 步骤 1 中的图像 2,3 Polaroid Onestep Close Up Forward Viewfinder Replacement, Flash Assembly Removal: 步骤 1 中的图像 3,3
    • Begin by opening the top of the camera (flash assembly) to a slight angle.
    • Next, angle the flash assembly slightly upward and pry off the connections carefully.
    • Be careful not to damage the ribbon cable. This is essential to the operation of the flash.
  2. Polaroid Onestep Close Up Forward Viewfinder Replacement, Opening Film Tray: 步骤 2 中的图像 1,2 Polaroid Onestep Close Up Forward Viewfinder Replacement, Opening Film Tray: 步骤 2 中的图像 2,2
    • Slide the action button, on the bottom of the camera, to open the bottom.
  3. Polaroid Onestep Close Up Forward Viewfinder Replacement, Removing Face Plate: 步骤 3 中的图像 1,3 Polaroid Onestep Close Up Forward Viewfinder Replacement, Removing Face Plate: 步骤 3 中的图像 2,3 Polaroid Onestep Close Up Forward Viewfinder Replacement, Removing Face Plate: 步骤 3 中的图像 3,3
    • Insert the blue plastic opening tool between the rear case and the plastic tabs directly under the shelf, and pry it loose.
    • Pull off the face plate.
  4. Polaroid Onestep Close Up Forward Viewfinder Replacement, Removing the Slider: 步骤 4 中的图像 1,1
    • Once you have the face plate removed the first thing to do is pry off the slider (the light grey bar near the bottom). The easiest way to accomplish this is to place the tweezers where the red circles are to pop the piece out.
  5. Polaroid Onestep Close Up Forward Viewfinder Replacement, Removing the Face Plate: 步骤 5 中的图像 1,3 Polaroid Onestep Close Up Forward Viewfinder Replacement, Removing the Face Plate: 步骤 5 中的图像 2,3 Polaroid Onestep Close Up Forward Viewfinder Replacement, Removing the Face Plate: 步骤 5 中的图像 3,3
    • Use the tweezers at the locations shown in the first two pictures to remove the face plate shown in the third picture.
    • This is a pretty secure fit in most cases so it might take a bit of tinkering to get the plate to pop off.
  6. Polaroid Onestep Close Up Forward Viewfinder Replacement, Removing the Forward Viewfinder: 步骤 6 中的图像 1,1
    • With the plate removed the lens should be easy enough to pop out.
    • If you don't want to dirty the lens it would be best to put on gloves or handle the lens with a rag of some kind.
结论
另外一个人完成了本指南。
Jordan
于09/22/14注册
471 声望
创作了2篇指南
团队
USF Tampa, Team 3-5, Brown Fall 2014 USF Tampa, Team 3-5, Brown Fall 2014 的会员
USFT-BROWN-F14S3G5
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 1,370
