跳转到主内容
Polaroid Onestep Close Up Close Up Lens Replacement
你所需要的
  1. Polaroid Onestep Close Up Close Up Lens Replacement, Flash Assembly Removal: 步骤 1 中的图像 1,3 Polaroid Onestep Close Up Close Up Lens Replacement, Flash Assembly Removal: 步骤 1 中的图像 2,3 Polaroid Onestep Close Up Close Up Lens Replacement, Flash Assembly Removal: 步骤 1 中的图像 3,3
    • Begin by opening the top of the camera (flash assembly) to a slight angle.
    • Next, angle the flash assembly slightly upward and pry off the connections carefully.
    • Be careful not to damage the ribbon cable. This is essential to the operation of the flash.
  2. Polaroid Onestep Close Up Close Up Lens Replacement, Opening Film Tray: 步骤 2 中的图像 1,2 Polaroid Onestep Close Up Close Up Lens Replacement, Opening Film Tray: 步骤 2 中的图像 2,2
    • Slide the action button, on the bottom of the camera, to open the bottom.
  3. Polaroid Onestep Close Up Close Up Lens Replacement, Removing Face Plate: 步骤 3 中的图像 1,3 Polaroid Onestep Close Up Close Up Lens Replacement, Removing Face Plate: 步骤 3 中的图像 2,3 Polaroid Onestep Close Up Close Up Lens Replacement, Removing Face Plate: 步骤 3 中的图像 3,3
    • Insert the blue plastic opening tool between the rear case and the plastic tabs directly under the shelf, and pry it loose.
    • Pull off the face plate.
  4. Polaroid Onestep Close Up Close Up Lens Replacement, Removing the slider: 步骤 4 中的图像 1,1
    • Pry off the slider (the light gray piece) by slipping it out from beneath the tabs (their location is indicated by the two red circles).
  5. Polaroid Onestep Close Up Close Up Lens Replacement, Removing the Face Plate: 步骤 5 中的图像 1,3 Polaroid Onestep Close Up Close Up Lens Replacement, Removing the Face Plate: 步骤 5 中的图像 2,3 Polaroid Onestep Close Up Close Up Lens Replacement, Removing the Face Plate: 步骤 5 中的图像 3,3
    • Pry off the face plate at the locations shown by using a rigid prying tool (either tweezers or the blue plastic opening tool). These spaces can be very tight.
    • You'll know if you were successful if you can fully remove the face plate.
  6. Polaroid Onestep Close Up Close Up Lens Replacement, Removing the Spring: 步骤 6 中的图像 1,2 Polaroid Onestep Close Up Close Up Lens Replacement, Removing the Spring: 步骤 6 中的图像 2,2
    • Use tweezers to lift the ring of the spring off of the hook it is attached to.
    • Gently loosen and remove the spring.
  7. Polaroid Onestep Close Up Close Up Lens Replacement, Removing the First Part of the Close Up Lens: 步骤 7 中的图像 1,2 Polaroid Onestep Close Up Close Up Lens Replacement, Removing the First Part of the Close Up Lens: 步骤 7 中的图像 2,2
    • Slide the CloseUp lens piece all the way to the left. It should separate without any resistance.
  8. Polaroid Onestep Close Up Close Up Lens Replacement, Removing the Second Part of the Close Up Lens: 步骤 8 中的图像 1,2 Polaroid Onestep Close Up Close Up Lens Replacement, Removing the Second Part of the Close Up Lens: 步骤 8 中的图像 2,2
    • Make sure the last plastic piece is set all the way to the right. Using the blue plastic tool, pry it loose. It should easily pop out.
结论
2等其他人完成本指南。
Jordan
于09/22/14注册
471 声望
创作了2篇指南
团队
USF Tampa, Team 3-5, Brown Fall 2014 USF Tampa, Team 3-5, Brown Fall 2014 的会员
USFT-BROWN-F14S3G5
3 名成员
创作了6篇指南
2条评论
Which model is the "precious" one?
Dan Brown - 回复
anyone know where i can buy the close up lens?
finbarlaverty - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 21
总计 1,837
