跳转到主内容
Polaroid One-Step 600 Lens Replacement
你所需要的
  1. Polaroid One-Step 600 Lens Replacement, Lens: 步骤 1 中的图像 1,3 Polaroid One-Step 600 Lens Replacement, Lens: 步骤 1 中的图像 2,3 Polaroid One-Step 600 Lens Replacement, Lens: 步骤 1 中的图像 3,3
    • Open the flash compartment of the camera so it makes a 30 degree angle with the horizontal.
  2. Polaroid One-Step 600 Lens Replacement: 步骤 2 中的图像 1,3 Polaroid One-Step 600 Lens Replacement: 步骤 2 中的图像 2,3 Polaroid One-Step 600 Lens Replacement: 步骤 2 中的图像 3,3
    • Separate the flash section of the camera from the main body by unhooking the sides with the spudger.
    • BE CAREFUL NOT TO YANK THE TWO SECTIONS APART BECAUSE THE BAND WIRE STILL ATTACHES THEM!
  3. Polaroid One-Step 600 Lens Replacement: 步骤 3 中的图像 1,3 Polaroid One-Step 600 Lens Replacement: 步骤 3 中的图像 2,3 Polaroid One-Step 600 Lens Replacement: 步骤 3 中的图像 3,3
    • Fully open the battery/ cartridge compartment by sliding the side tab toward you.
  4. Polaroid One-Step 600 Lens Replacement: 步骤 4 中的图像 1,3 Polaroid One-Step 600 Lens Replacement: 步骤 4 中的图像 2,3 Polaroid One-Step 600 Lens Replacement: 步骤 4 中的图像 3,3
    • Insert spudger in between face of camera and sides where the four tabs are located.
    • BE CAREFUL! The button that is pressed to take a picture may pop out of the camera at this step.
  5. Polaroid One-Step 600 Lens Replacement: 步骤 5 中的图像 1,2 Polaroid One-Step 600 Lens Replacement: 步骤 5 中的图像 2,2
    • Once tabs are released, pull face of camera straight out.
  6. Polaroid One-Step 600 Lens Replacement: 步骤 6 中的图像 1,1
    • Use spudger to twist the notch on the lens into the opening to remove it.
  7. Polaroid One-Step 600 Lens Replacement: 步骤 7 中的图像 1,2 Polaroid One-Step 600 Lens Replacement: 步骤 7 中的图像 2,2
    • Carefully use spudger to release lens, then lift lens out of camera with fingers.
    • CAUTION: LENS MAY POP OUT OF CAMERA; REMOVE CAREFULLY.
  8. Polaroid One-Step 600 Lens Replacement: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    Microfiber Cleaning Cloths
    $3.99
    购买
    • Clean old lens with a microfiber cloth or get a new lens to put back into the camera.
结论
8等其他人完成本指南。
Doug Jimenez
于01/21/10注册
538 声望
创作了2篇指南
团队
Cal Poly, Team 16-31, Maness Winter 2010 Cal Poly, Team 16-31, Maness Winter 2010 的会员
CPSU-MANESS-W10S16G31
4 名成员
创作了6篇指南
一条评论
Hi, since you seem to know stuff about Polaroid cameras, I was wondering if you could help me figure out what is wrong with mine. I have a Polaroid Instant One-Step and whenever I take pictures, they never fully develop. They are a blue-ish hue and are never clear. Is this because of the lens do you think? Or something completely different?
Thanks
H.Rose - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 8
过去 30 天: 33
总计 16,114
