跳转到主内容
Polaroid One-Step 600 Battery Cartridge Replacement
  1. Polaroid One-Step 600 Battery Cartridge Replacement, Battery Cartridge: 步骤 1 中的图像 1,3 Polaroid One-Step 600 Battery Cartridge Replacement, Battery Cartridge: 步骤 1 中的图像 2,3 Polaroid One-Step 600 Battery Cartridge Replacement, Battery Cartridge: 步骤 1 中的图像 3,3
    • Open the bottom compartment of the camera by sliding the lever towards the opening.
  2. Polaroid One-Step 600 Battery Cartridge Replacement: 步骤 2 中的图像 1,1
    • Remove old battery/ film cartridge from camera.
  3. Polaroid One-Step 600 Battery Cartridge Replacement: 步骤 3 中的图像 1,1
    • Follow the instructions that came with the new battery/ film cartridge to insert the new cartridge into the camera.
    • Close the battery compartment of the camera.
    • Note: The camera in this picture does not contain a battery.
终点
13等其他人完成本指南。
Doug Jimenez
于01/21/10注册
538 声望
创作了2篇指南
团队
Cal Poly, Team 16-31, Maness Winter 2010 Cal Poly, Team 16-31, Maness Winter 2010 的会员
CPSU-MANESS-W10S16G31
4 名成员
创作了6篇指南
13条评论
It worked but its expensive
Jessica diaz - 回复
I put new film in, it´s turning on, the flash is going off, but no film is coming out after the flash. What is the problem?
tristanmoeller2013 - 回复
nothing happened
new film installed
no sound
no flash
no action
eminickstone - 回复
I'm having the same issue
Marie -
I'm having same issue.
Marie -
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 89
过去 30 天: 365
总计 149,214
