1. Turn the entire device over, so that the underside of the device is facing upward. With the underside of the device facing up, locate the 11mm screw found in each far corner of the device. Remove the single 11mm screw from each of the four corners, using the Phillips #0 screwdriver.
    • Turn the entire device over, so that the underside of the device is facing upward.
    • With the underside of the device facing up, locate the 11mm screw found in each far corner of the device. Remove the single 11mm screw from each of the four corners, using the Phillips #0 screwdriver.
  2. Turn the device so that the underside faces you, and the edge where the case and device bind, faces upward. The opening of the device should be face down. In this position you will see a crease line between the device and the top cover. Gently Insert your blue plastic opening tool into the crack of the crease line, between the front and back cover to separate them.
    • Turn the device so that the underside faces you, and the edge where the case and device bind, faces upward. The opening of the device should be face down.
    • In this position you will see a crease line between the device and the top cover. Gently Insert your blue plastic opening tool into the crack of the crease line, between the front and back cover to separate them.
    • Be careful when separating the front and back covers, as the two are held together by a thin wire.
    • Separate the halves of the case.
  3. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. Locate the input/output board on the top left hand corner of the device. It will look like a green circuit board with wires protruding and connecting to the case cover.
    • Locate the input/output board on the top left hand corner of the device. It will look like a green circuit board with wires protruding and connecting to the case cover.
    • Using your blue plastic opening tool, disconnect the multicolored wires located on the input/output board. These will be the same multicolored wires that connect the back cover to the input/output board.
  5. Use a Philips #0 screwdriver to remove the screws for the bar you are replacing.
    • Use a Philips #0 screwdriver to remove the screws for the bar you are replacing.
  6. Slide out the bar.
    • Slide out the bar.
结论
Kevin
于2012年01月20日注册
19 信誉积分
创作了2篇指南
团队
Cal Poly, Team 8-14, Maness Winter 2012 Cal Poly, Team 8-14, Maness Winter 2012 的会员
CPSU-MANESS-W12S8G14
4 名成员
创作了8篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 720
