跳转到主内容
加入维修社区 - 创建账户
Polaroid Cube Video Quality Switch Replacement
你所需要的
  1. Polaroid Cube Video Quality Switch Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the SD card cover by twisting it using a Plastic Opening Tool
  2. Polaroid Cube Video Quality Switch Replacement: 步骤 2 中的图像 1,1
    • Use the Plastic Opening tool to pry off and remove the front cover.
  3. Polaroid Cube Video Quality Switch Replacement: 步骤 3 中的图像 1,1
    • Using a J00 head screwdriver, remove the four 3.27mm screws from the front of the camera near the lens.
  4. Polaroid Cube Video Quality Switch Replacement: 步骤 4 中的图像 1,2 Polaroid Cube Video Quality Switch Replacement: 步骤 4 中的图像 2,2
    • Use the Plastic Opening Tool to pry open the shell of the camera.
    • There are four latches, one at each corner, that you will need to detach.
  5. Polaroid Cube Video Quality Switch Replacement: 步骤 5 中的图像 1,1
    • Remove shell from top and bottom of camera.
  6. Polaroid Cube Video Quality Switch Replacement: 步骤 6 中的图像 1,1
    • Remove the rubber seal wrapped around the camera.
  7. Polaroid Cube Video Quality Switch Replacement: 步骤 7 中的图像 1,2 Polaroid Cube Video Quality Switch Replacement: 步骤 7 中的图像 2,2
    • Remove the tape wrapped around the battery.
  8. Polaroid Cube Video Quality Switch Replacement: 步骤 8 中的图像 1,3 Polaroid Cube Video Quality Switch Replacement: 步骤 8 中的图像 2,3 Polaroid Cube Video Quality Switch Replacement: 步骤 8 中的图像 3,3
    • Using a J00 head screwdriver, unscrew the four 3.46mm screws from the top and bottom circuit board.
  9. Polaroid Cube Video Quality Switch Replacement: 步骤 9 中的图像 1,2 Polaroid Cube Video Quality Switch Replacement: 步骤 9 中的图像 2,2
    • Use the plastic opening tool to remove the circuit board that the battery is connected to.
  10. Polaroid Cube Video Quality Switch Replacement: 步骤 10 中的图像 1,1
    • Gently remove the battery pin connector from the circuit board.
  11. Polaroid Cube Video Quality Switch Replacement, Video Quality Switch: 步骤 11 中的图像 1,2 Polaroid Cube Video Quality Switch Replacement, Video Quality Switch: 步骤 11 中的图像 2,2
    • Using a J00 head screwdriver, unscrew the 3.46mm screw that connects the top circuit board to the video quality switch board.
  12. Polaroid Cube Video Quality Switch Replacement: 步骤 12 中的图像 1,1
    • Remove the circuit board.
  13. Polaroid Cube Video Quality Switch Replacement: 步骤 13 中的图像 1,2 Polaroid Cube Video Quality Switch Replacement: 步骤 13 中的图像 2,2
    • Using a J00 head screwdriver, unscrew the two 3.46mm screws connecting the video quality switch to the case.
    • Remove and replace the broken video quality switch.
结论
4等其他人完成本指南。
Grant Baldwin
于09/29/16注册
685 声望
创作了2篇指南
团队
IUPUI, Team 3-2, Harley Fall 2016 IUPUI, Team 3-2, Harley Fall 2016 的会员
IUPUI-HARLEY-F16S3G2
4 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 1,146
