跳转到主内容
加入维修社区 - 创建账户
Polaroid Cube Lens Replacement
你所需要的
  1. Polaroid Cube Lens Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the SD card cover by twisting it using a Plastic Opening Tool
  2. Polaroid Cube Lens Replacement: 步骤 2 中的图像 1,1
    • Use the Plastic Opening tool to pry off and remove the front cover.
  3. Polaroid Cube Lens Replacement: 步骤 3 中的图像 1,1
    • Using a J00 head screwdriver, remove the four 3.27mm screws from the front of the camera near the lens.
  4. Polaroid Cube Lens Replacement: 步骤 4 中的图像 1,2 Polaroid Cube Lens Replacement: 步骤 4 中的图像 2,2
    • Use the Plastic Opening Tool to pry open the shell of the camera.
    • There are four latches, one at each corner, that you will need to detach.
  5. Polaroid Cube Lens Replacement: 步骤 5 中的图像 1,1
    • Remove shell from top and bottom of camera.
  6. Polaroid Cube Lens Replacement: 步骤 6 中的图像 1,1
    • Remove the rubber seal wrapped around the camera.
  7. Polaroid Cube Lens Replacement: 步骤 7 中的图像 1,2 Polaroid Cube Lens Replacement: 步骤 7 中的图像 2,2
    • Remove the tape wrapped around the battery.
  8. Polaroid Cube Lens Replacement: 步骤 8 中的图像 1,3 Polaroid Cube Lens Replacement: 步骤 8 中的图像 2,3 Polaroid Cube Lens Replacement: 步骤 8 中的图像 3,3
    • Using a J00 head screwdriver, unscrew the four 3.46mm screws from the top and bottom circuit board.
  9. Polaroid Cube Lens Replacement: 步骤 9 中的图像 1,2 Polaroid Cube Lens Replacement: 步骤 9 中的图像 2,2
    • Use the plastic opening tool to remove the circuit board that the battery is connected to.
  10. Polaroid Cube Lens Replacement: 步骤 10 中的图像 1,1
    • Gently remove the battery pin connector from the circuit board.
  11. Polaroid Cube Lens Replacement, Lens: 步骤 11 中的图像 1,2 Polaroid Cube Lens Replacement, Lens: 步骤 11 中的图像 2,2
    • Use a J00 screwdriver to unscrew the two circled 3.5mm Phillips-head screws from the circuit board.
  12. Polaroid Cube Lens Replacement: 步骤 12 中的图像 1,2 Polaroid Cube Lens Replacement: 步骤 12 中的图像 2,2
    • Use a J00 head screwdriver to unscrew the two 3.5mm screws from the circuit board.
  13. Polaroid Cube Lens Replacement: 步骤 13 中的图像 1,1
    • Remove the lens from the unscrewed circuit board and replace the broken lens.
结论
4等其他人完成本指南。
Grant Baldwin
于09/29/16注册
685 声望
创作了2篇指南
团队
IUPUI, Team 3-2, Harley Fall 2016 IUPUI, Team 3-2, Harley Fall 2016 的会员
IUPUI-HARLEY-F16S3G2
4 名成员
创作了3篇指南
2指南评论
Where can I find a replacement lens for the cube+? I broke the bubble part of the lens
Ben McAlister - 回复 分享
Maybe is posable replace wider view angle lens ? original looks like fpv camera lens foxeer or runcam micro. Possibly Caddx micro cam lens
starsas777 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 24
总计 2,583
