跳转到主内容
加入维修社区 - 创建账户
Polaroid Cube Battery Replacement
你所需要的
  1. Polaroid Cube Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the SD card cover by twisting it using a Plastic Opening Tool
  2. Polaroid Cube Battery Replacement: 步骤 2 中的图像 1,1
    • Use the Plastic Opening tool to pry off and remove the front cover.
  3. Polaroid Cube Battery Replacement: 步骤 3 中的图像 1,1
    • Using a J00 head screwdriver, remove the four 3.27mm screws from the front of the camera near the lens.
  4. Polaroid Cube Battery Replacement: 步骤 4 中的图像 1,2 Polaroid Cube Battery Replacement: 步骤 4 中的图像 2,2
    • Use the Plastic Opening Tool to pry open the shell of the camera.
    • There are four latches, one at each corner, that you will need to detach.
  5. Polaroid Cube Battery Replacement: 步骤 5 中的图像 1,1
    • Remove shell from top and bottom of camera.
  6. Polaroid Cube Battery Replacement: 步骤 6 中的图像 1,1
    • Remove the rubber seal wrapped around the camera.
  7. Polaroid Cube Battery Replacement: 步骤 7 中的图像 1,2 Polaroid Cube Battery Replacement: 步骤 7 中的图像 2,2
    • Remove the tape wrapped around the battery.
  8. Polaroid Cube Battery Replacement: 步骤 8 中的图像 1,3 Polaroid Cube Battery Replacement: 步骤 8 中的图像 2,3 Polaroid Cube Battery Replacement: 步骤 8 中的图像 3,3
    • Using a J00 head screwdriver, unscrew the four 3.46mm screws from the top and bottom circuit board.
  9. Polaroid Cube Battery Replacement: 步骤 9 中的图像 1,2 Polaroid Cube Battery Replacement: 步骤 9 中的图像 2,2
    • Use the plastic opening tool to remove the circuit board that the battery is connected to.
  10. Polaroid Cube Battery Replacement: 步骤 10 中的图像 1,1
    • Gently remove the battery pin connector from the circuit board.
结论
10等其他人完成本指南。
heath lamkin
于09/29/16注册
372 声望
撰写一个指南
团队
IUPUI, Team 3-2, Harley Fall 2016 IUPUI, Team 3-2, Harley Fall 2016 的会员
IUPUI-HARLEY-F16S3G2
4 名成员
创作了3篇指南
13指南评论
Any idea where to find the replacement batteries?
hooverhogg - 回复 分享
Well described! Need to buy a replacement battery though but I have no idea about the specs of the battery. Any information?
seyhangul - 回复 分享
Fuji 402424 Lithium ion (Pouch)battery 240mA 4.8V Can’t find it. Can anyone help with a source?
David F O'Connor - 分享
Was anyone able to to find the replacement batteries for the Cube?
yzorger - 回复 分享
the cube requires a two-pack battery which has a single plug for both of them and so they have to be wired together in just the right way to be able to fit inside the cube. i guess it's not possible to buy replacement batt. and paying minimum $16 for it? u could just buy a new one for too close to $16. or a used one.
Timothy Davenport - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 74
总计 10,549
