跳转到主内容
Polaroid A10 Motherboard Replacement
你所需要的
  1. Polaroid A10 Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,3 Polaroid A10 Motherboard Replacement, Back Cover: 步骤 1 中的图像 2,3 Polaroid A10 Motherboard Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Begin by having the side with volume and power button face up towards you.
    • Insert a plastic opening tool between the display and the back cover.
    • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
    • It is easier to remove the back cover, if the display screen is faced down.
    • The tabs must be released from all four sides before removing the back cover.
  2. Polaroid A10 Motherboard Replacement, Motherboard: 步骤 2 中的图像 1,3 Polaroid A10 Motherboard Replacement, Motherboard: 步骤 2 中的图像 2,3 Polaroid A10 Motherboard Replacement, Motherboard: 步骤 2 中的图像 3,3
    • Take off yellow tapes that are surrounding the motherboard.
    • Use the plastic opening tools to disconnect the three ribbon cables: battery, screen, and volume/power buttons.
  3. Polaroid A10 Motherboard Replacement: 步骤 3 中的图像 1,3 Polaroid A10 Motherboard Replacement: 步骤 3 中的图像 2,3 Polaroid A10 Motherboard Replacement: 步骤 3 中的图像 3,3
    • Using the Phillips #000 screwdriver, remove the four 5 mm screws located in the picture by rotating the screw counter-clockwise.
  4. Polaroid A10 Motherboard Replacement: 步骤 4 中的图像 1,2 Polaroid A10 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Use the soldering tool to unsolder the two bigger metals from the wires of the battery.
    • Use the same soldering tool to unsolder the four smaller metals from the wires of the speakers.
    • Use the same soldering tool to unsolder the ground wire.
    • Removal and installation of wires requires soldering. Here's a helpful link to assist you with great soldering techniques.
  5. Polaroid A10 Motherboard Replacement: 步骤 5 中的图像 1,3 Polaroid A10 Motherboard Replacement: 步骤 5 中的图像 2,3 Polaroid A10 Motherboard Replacement: 步骤 5 中的图像 3,3
    • Gently lift the motherboard up and out of the device.
结论
另外一个人完成了本指南。
Tracie
于01/22/15注册
119 声望
撰写一个指南
团队
UW Tacoma, Team 3-3, Rose Winter 2015 UW Tacoma, Team 3-3, Rose Winter 2015 的会员
UWT-ROSE-W15S3G3
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 587
