跳转到主内容
Polaroid A10 Battery Replacement
你所需要的
  1. Polaroid A10 Battery Replacement, Back Cover: 步骤 1 中的图像 1,3 Polaroid A10 Battery Replacement, Back Cover: 步骤 1 中的图像 2,3 Polaroid A10 Battery Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Begin by having the side with volume and power button face up towards you.
    • Insert a plastic opening tool between the display and the back cover.
    • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
    • It is easier to remove the back cover, if the display screen is faced down.
    • The tabs must be released from all four sides before removing the back cover.
  2. Polaroid A10 Battery Replacement, Battery: 步骤 2 中的图像 1,3 Polaroid A10 Battery Replacement, Battery: 步骤 2 中的图像 2,3 Polaroid A10 Battery Replacement, Battery: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    购买
    • Begin by inserting the flat end of a spudger underneath the battery to separate the glue from the battery.
    • It is better to use a plastic card if you have one.
    • Gently lift up the battery as you continue to separate the glue from the battery.
    • Lift up just enough to see where the glue is, so that you don't bend the battery.
    • Once the glue has been separated, gently lift up the battery and you will notice two wires attached to the motherboard.
  3. Polaroid A10 Battery Replacement: 步骤 3 中的图像 1,3 Polaroid A10 Battery Replacement: 步骤 3 中的图像 2,3 Polaroid A10 Battery Replacement: 步骤 3 中的图像 3,3
  4. Polaroid A10 Battery Replacement: 步骤 4 中的图像 1,1
    • Gently lift the battery up and out of the device.
结论
另外一个人完成了本指南。
armando
于01/14/15注册
150 声望
撰写一个指南
团队
UW Tacoma, Team 3-3, Rose Winter 2015 UW Tacoma, Team 3-3, Rose Winter 2015 的会员
UWT-ROSE-W15S3G3
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 726
