跳转到主内容
Polar V800 Waterproofing Seal Replacement
你所需要的
  1. Polar V800 Waterproofing Seal Replacement, Waterproofing Seal: 步骤 1 中的图像 1,2 Polar V800 Waterproofing Seal Replacement, Waterproofing Seal: 步骤 1 中的图像 2,2
    • In this guide, the wrist band of the Polar V800 is removed for a clear view of the back panel. If you find it helpful, you may want to remove the wrist strap. Please reference the Watch Band Replacement guide for removal instructions if you wish to do so.
    • Ensure your Polar V800 sports watch is powered off before continuing.
    • Remove the eight, 7.4 millimeter-long screws on the back of the watch with a T5 head-type, torque screwdriver.
  2. Polar V800 Waterproofing Seal Replacement: 步骤 2 中的图像 1,3 Polar V800 Waterproofing Seal Replacement: 步骤 2 中的图像 2,3 Polar V800 Waterproofing Seal Replacement: 步骤 2 中的图像 3,3
    • Gently separate the watch housing from the back panel.
    • The watch should come apart easily after removing the screws. If you experience difficulties separating the housing and and back cover, use a spudger to gently pry apart the back panel and the button and screen protector housing.
  3. Polar V800 Waterproofing Seal Replacement: 步骤 3 中的图像 1,2 Polar V800 Waterproofing Seal Replacement: 步骤 3 中的图像 2,2
    • The waterproofing seal is the red, elastic band that surrounds the display of the watch.
    • Remove the waterproofing seal.
    • During reassembly, align the red seal in the groove surrounding the glass screen on the main watch housing to ensure a watertight seal.
结论
5等其他人完成本指南。
Jarod Lyles
于04/18/18注册
833 声望
创作了5篇指南
团队
Cal Poly, Team S17-G6, Livingston Spring 2018 Cal Poly, Team S17-G6, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S17G6
4 名成员
创作了8篇指南
2条评论
Wo kann ich eine neue rote? Abdichtung für Polar V 800 kaufen?
Noa Schulz - 回复
Bitte kurze Info.
Danke
Noa Schulz - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 24
总计 3,004
