跳转到主内容
Polar V800 Watch Band Replacement
你所需要的
  1. Polar V800 Watch Band Replacement, Watch Band: 步骤 1 中的图像 1,3 Polar V800 Watch Band Replacement, Watch Band: 步骤 1 中的图像 2,3 Polar V800 Watch Band Replacement, Watch Band: 步骤 1 中的图像 3,3
    • Using a narrow object like a paperclip, push the pins located in the watch band in the direction of the arrow indicated on the watch.
    • Completely pull out the pins.
    • It isn't necessary to remove the watch band before replacing other parts of the watch, but it may make removal of other elements of the watch more accessible and clear.
    • When replacing the charging port cover, only take out the pin that is closest to the charging port cover.
  2. Polar V800 Watch Band Replacement: 步骤 2 中的图像 1,3 Polar V800 Watch Band Replacement: 步骤 2 中的图像 2,3 Polar V800 Watch Band Replacement: 步骤 2 中的图像 3,3
    • To remove the watch band, pull each end of the watch band away from the watch frame.
结论
另外一个人完成了本指南。
Jarod Lyles
于04/18/18注册
833 声望
创作了5篇指南
团队
Cal Poly, Team S17-G6, Livingston Spring 2018 Cal Poly, Team S17-G6, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S17G6
4 名成员
创作了8篇指南
8条评论
There is no way for me to remove the clips, they are stuck and don’t move, any ideas on how to loosen them?
Gustavo Fette - 回复
I have the same issue. Any idea?
smichaud777 - 回复
Same issue here, they wont budge. You guys above found any solution?
Kris - 回复
No, I guess I won’t Be buying Polar stuff no more… can’t believe it…
Gustavo Fette -
The Pins move out! Like described above, there is one side with a larger head of the pin. This is the side where the pin comes out. The smaller side is where you push. Due to water and sweat, there is some kind off corrosion or buildup around the pin.This is why it does not come out easy. Important is to use right size of the tool. Lubrication with WD40 silicone oil helps.
Michael_B - 回复
Well done - nice and easy. I thought I might have to unscrew the screws but no, the pin just pushes out. Clearly explained. Thank you.
Alan Kirk - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 30
总计 7,435
