跳转到主内容
Polar V800 Charging Port Cover Replacement
你所需要的
  1. Polar V800 Charging Port Cover Replacement, Watch Band: 步骤 1 中的图像 1,3 Polar V800 Charging Port Cover Replacement, Watch Band: 步骤 1 中的图像 2,3 Polar V800 Charging Port Cover Replacement, Watch Band: 步骤 1 中的图像 3,3
    • Using a narrow object like a paperclip, push the pins located in the watch band in the direction of the arrow indicated on the watch.
    • Completely pull out the pins.
    • It isn't necessary to remove the watch band before replacing other parts of the watch, but it may make removal of other elements of the watch more accessible and clear.
    • When replacing the charging port cover, only take out the pin that is closest to the charging port cover.
  2. Polar V800 Charging Port Cover Replacement: 步骤 2 中的图像 1,3 Polar V800 Charging Port Cover Replacement: 步骤 2 中的图像 2,3 Polar V800 Charging Port Cover Replacement: 步骤 2 中的图像 3,3
    • To remove the watch band, pull each end of the watch band away from the watch frame.
  3. Polar V800 Charging Port Cover Replacement, Charging Port Cover: 步骤 3 中的图像 1,3 Polar V800 Charging Port Cover Replacement, Charging Port Cover: 步骤 3 中的图像 2,3 Polar V800 Charging Port Cover Replacement, Charging Port Cover: 步骤 3 中的图像 3,3
    • Take off the charging port cover.
结论
另外一个人完成了本指南。
Nick B.
于04/29/18注册
387 声望
撰写一个指南
团队
Cal Poly, Team S17-G6, Livingston Spring 2018 Cal Poly, Team S17-G6, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S17G6
4 名成员
创作了8篇指南
一条评论
where does not procure the battery port cover ?
Chenthill P - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 2,929
