此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
简介
转到步骤 1 ↓本指南将向用户演示如何拆卸并更换 Polar V800 运动手表上的表带。如果你的表带需要更换为不同尺寸的款式,或者表带已经损坏或磨损,本指南将帮助你让手表恢复原状(回到你的手腕上!)。
你所需要的
工具
要重新组装设备,请按相反顺序执行这些说明。
另外一个人完成了本指南。
8指南评论
There is no way for me to remove the clips, they are stuck and don’t move, any ideas on how to loosen them?
I have the same issue. Any idea?
smichaud777 - 回复 分享
The Pins move out! Like described above, there is one side with a larger head of the pin. This is the side where the pin comes out. The smaller side is where you push. Due to water and sweat, there is some kind off corrosion or buildup around the pin.This is why it does not come out easy. Important is to use right size of the tool. Lubrication with WD40 silicone oil helps.
