跳转到主内容
Polar M400 Watch micro-USB connector Replacement
你所需要的
  1. Polar M400 Watch micro-USB connector Replacement, Disconnecting the flex PCB: 步骤 1 中的图像 1,3 Polar M400 Watch micro-USB connector Replacement, Disconnecting the flex PCB: 步骤 1 中的图像 2,3 Polar M400 Watch micro-USB connector Replacement, Disconnecting the flex PCB: 步骤 1 中的图像 3,3
    • Follow the screen replacement tutorial to dismantle the watch.
    • Carefully lift the screen from the board.
    • Disconnect the USB's flex PCB from the main board. Save the red rubber seal of the USB connector for later.
    • Use a tool like a helping hand to hold the USB connector part.
    • Using a heat gun, blow hot air underneath the PCB.
    • Once the solder is melting give the connector a good tap in order to make the PCB fall loose.
  2. Polar M400 Watch micro-USB connector Replacement, Soldering a new USB connector: 步骤 3 中的图像 1,2 Polar M400 Watch micro-USB connector Replacement, Soldering a new USB connector: 步骤 3 中的图像 2,2
    • Place the new USB connector on a flat surface with its pins pointing upwards.
    • Place the PCB on top on the pins, the exposed copper traces on the flex PCB facing the flat surface.
    • Using an iron, solder the PCB by heating all the pads at the same time (as much as possible) and apply pressure so that the pins of the USB connector come through.
  3. Polar M400 Watch micro-USB connector Replacement, Sealing the USB connector: 步骤 4 中的图像 1,2 Polar M400 Watch micro-USB connector Replacement, Sealing the USB connector: 步骤 4 中的图像 2,2
    • Connect the flex PCB back to the main board.
    • Reassemble the watch stopping before screwing the lid back.
    • Add hot glue to the base of the USB connector filling the watch case's cavity. Be careful not to put hot glue inside the connector.
    • While the glue is still hot, put the red rubber seal back on top.
    • Screw the lid back.
结论
6等其他人完成本指南。
Benjamin Freeman
于01/16/20注册
289 声望
撰写一个指南
10条评论
Sehr gute Beschreibung,
aber ich finde keine USB-Buchse für die M400 zu kaufen
Wo gibt's die Teile?
martinmartinez644 - 回复
Danke schön. Für den Konnektor allein habe ich auf Aliexpress gekauft : https://www.aliexpress.com/item/32960430...
Benjamin Freeman -
From where do I order usb connector?
Pankaj Singh - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 63
过去 30 天: 267
总计 16,899
