跳转到主内容
Polar M400 Watch Screen Replacement
你所需要的
  1. Polar M400 Watch Screen Replacement, Wrist Strap: 步骤 1 中的图像 1,1
    • Insert a standard paper clip into the holes on both sides of the watch that connect the watch's face with the wrist strap.
  2. Polar M400 Watch Screen Replacement: 步骤 2 中的图像 1,2 Polar M400 Watch Screen Replacement: 步骤 2 中的图像 2,2
    • Apply an upward pressure to the holes until the locking pins release.
    • Use precision tweezers to remove the pins that connect the face with the strap.
  3. Polar M400 Watch Screen Replacement: 步骤 3 中的图像 1,1
    • Once the pins are released, the old wrist strap should snap off.
    • Simply lock the new wrist strap into place.
  4. Polar M400 Watch Screen Replacement, Battery: 步骤 4 中的图像 1,1
    • Use the T5 head on the iFixit screwdriver to unscrew the four screws on the back of the watch’s face.
  5. Polar M400 Watch Screen Replacement: 步骤 5 中的图像 1,2 Polar M400 Watch Screen Replacement: 步骤 5 中的图像 2,2
    • Gently remove the backing from the watch.
  6. Polar M400 Watch Screen Replacement: 步骤 6 中的图像 1,2 Polar M400 Watch Screen Replacement: 步骤 6 中的图像 2,2
    • Use tweezers to gently pry the golden sensor away from the battery.
    • Remove battery using the plastic opening tools.
  7. Polar M400 Watch Screen Replacement, Screen: 步骤 7 中的图像 1,2 Polar M400 Watch Screen Replacement, Screen: 步骤 7 中的图像 2,2
    • Detach the screen from the screen protector using a PH000 screwdriver.
  8. Polar M400 Watch Screen Replacement: 步骤 8 中的图像 1,2 Polar M400 Watch Screen Replacement: 步骤 8 中的图像 2,2
    • Attach a new screen to the screen protector.
    • Make sure that the charging port remains accessible, as it can easily become detached during the replacement.
结论
5等其他人完成本指南。
团队
10条评论
Hi, where can i buy the replacement?
Thanks
Mario Sánchez-Barriga Marín - 回复
hi,where can I buy the usb replacement.
GamesFISH_1989 - 回复
Hi, were can i buy the replacement. Thanks
Julien Genon - 回复
https://www.allsystem.cz/
I bought a connector USB there… Maybe can be interesting for someone else…
manuel caudera - 回复
hello manuel,
i tried to order from the web site you specified, but it looks like they are not delivering in france,
cna you please tell me where else i can order this peice
Mathieu Poncet -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 69
总计 9,039
