跳转到主内容
Pokewalker Button Replacement
你所需要的
  1. Pokewalker Button Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the Screw on the Back of the Pokewalker.
  2. Pokewalker Button Replacement: 步骤 2 中的图像 1,1
    • Remove the Screw with a Phillips #0 Screwdriver
    • The screw is attached to the rear case with washers. don't worry about losing it.
  3. Pokewalker Button Replacement: 步骤 3 中的图像 1,1
    • Remove the Rear Cover from the Device
  4. Pokewalker Button Replacement: 步骤 4 中的图像 1,1
    • Use the flat end of a Spudger to Remove the Battery
    • Locate the 4 Screws Around the Device
    • Remove all 4 screws with a Y0 Triwing Screwdriver
    • Separate the 2 halves of the Device
    • Do not Separate Completely as the Display is Still Connected by a Ribbon Cable
    • Use a Spudger to Flip the Latch holding the ribbon cable in place and use Tweezers to Pull it out
    • Do not use Excessive force when reinserting the cable, because ribbon cables are fragile
    • Remove the Rubber-button thingy from the upper case
    • I have no idea what that thing is, edit this guide if you do.
    • Remove the 3 Plastic Buttons from the Case
    • It helps that the buttons only go in one way, makes it easier to reassemble
结论
Winni Stuart
于04/13/14注册
417 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 547
