跳转到主内容
Pokewalker Battery Replacement
你所需要的
  1. Pokewalker Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the Screw on the Back of the Pokewalker.
  2. Pokewalker Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the Screw with a Phillips #0 Screwdriver
    • The screw is attached to the rear case with washers. don't worry about losing it.
  3. Pokewalker Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the Rear Cover from the Device
  4. Pokewalker Battery Replacement: 步骤 4 中的图像 1,1
    • Use the flat end of a Spudger to Remove the Battery
结论
8等其他人完成本指南。
Winni Stuart
于04/13/14注册
417 声望
创作了2篇指南
2条评论
The battery must be placed positive side facing up if I am correct.
I just dug my pokewalker out of my closet. Been years since it has been used. Putting in an effort to get it running again.
Thanks for the tutorial.
Jake Allen - 回复
I just got my Pokéwalker up and running again as well. Nintendo's stuff is always so well made.
signature -
添加评论
浏览统计数据:
过去 24 小时: 19
过去 7 天: 132
过去 30 天: 546
总计 25,424
