跳转到主内容
加入维修社区 - 创建账户
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的Pokemon Go Plus,应参考我们的维修指南
  1. Pokemon Go Plus Teardown, Front and battery cover: 步骤 1 中的图像 1,2 Pokemon Go Plus Teardown, Front and battery cover: 步骤 1 中的图像 2,2
    • one phillips PH1 screw located on the back to remove the battery cover
  2. Pokemon Go Plus Teardown, Exterior plastics: 步骤 2 中的图像 1,3 Pokemon Go Plus Teardown, Exterior plastics: 步骤 2 中的图像 2,3 Pokemon Go Plus Teardown, Exterior plastics: 步骤 2 中的图像 3,3
    • Three Tri-point Y0 screws are located under the battery cover
    • Then the Red/White front plate comes out though the front
  3. Pokemon Go Plus Teardown, PCB Removal: 步骤 3 中的图像 1,2 Pokemon Go Plus Teardown, PCB Removal: 步骤 3 中的图像 2,2
    • the PCB is set on three plastic supports with only the pressure of the back screws to lock it in place
    • the PCB and vibration motor can be lifted out with only the slightest bit of pressure
  4. Pokemon Go Plus Teardown, PCB Front side: 步骤 4 中的图像 1,2 Pokemon Go Plus Teardown, PCB Front side: 步骤 4 中的图像 2,2
    • Function Button located in the center
    • Multi colour led beside button
  5. Pokemon Go Plus Teardown, PCB Back: 步骤 5 中的图像 1,2 Pokemon Go Plus Teardown, PCB Back: 步骤 5 中的图像 2,2
    • Insert wisdom here.
  6. Pokemon Go Plus Teardown, Embeded CPU: 步骤 6 中的图像 1,3 Pokemon Go Plus Teardown, Embeded CPU: 步骤 6 中的图像 2,3 Pokemon Go Plus Teardown, Embeded CPU: 步骤 6 中的图像 3,3
    • Dialog Semiconductors Embedded CPU DA14580
  7. Pokemon Go Plus Teardown, Programming headers: 步骤 7 中的图像 1,3 Pokemon Go Plus Teardown, Programming headers: 步骤 7 中的图像 2,3 Pokemon Go Plus Teardown, Programming headers: 步骤 7 中的图像 3,3
shawn
于03/21/15注册
138 声望
撰写一个指南
18指南评论
This post needs moar wisdom
corganowade - 回复
Anybody able to spot a Pedometer?
Luigi Lugmayr - 回复
There is no pedometer. It's just a Bluetooth clicker. Your phone's sensors track all movement.
traviswparker - 回复
What is the
"A1
HNG
SBJ"
chip in "step 6"?
I2C/SPI flash?
And.. what is in "Step 4" the chip? in between the capacitors and that "mostlikely MOSFETs for driving LEDs".
I'm looking at DA14580 modules on ebay:
http://www.ebay.com/sch/i.html?_from=R40...
And I tend to to say "let's try to clone this", the DA14580 has OTA programmable FLASH. :)
Badger - 回复
Last picture is most likely JTAG pogo contact points. For programming and testing. The board seems to be like 3-4+ layer board just based on the pictures. Also can't really tell you what chips those are with that quality of a picture. However the two little chips under the mounting hole on the picture in step 4 looks to be the DC Boost IC to keep constant voltage throughout the batteries life. The chip to the left of those boost converts is most likely the Bluetooth IC (just guessing by the location and the traces around it). Hope this helps :)
Jt Whissel - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 41
过去 30 天: 184
总计 30,319
