跳转到主内容
Pokémon™ GO Plus Battery Replacement
你所需要的
  1. Pokémon™ GO Plus Battery Replacement, Remove the two screws from the bottom: 步骤 1 中的图像 1,1
    • Flanking both sides of the charging port are J00 Screws. Remove these.
    • These screws go into plastic, so when re-assembling the device, be very careful not to over tighten them.
    • These two screws are identical to each other, but differ from the screws within the device, keep them separate from any screws you remove from within the device.
  2. Pokémon™ GO Plus Battery Replacement, Remove Faceplace: 步骤 2 中的图像 1,2 Pokémon™ GO Plus Battery Replacement, Remove Faceplace: 步骤 2 中的图像 2,2
    • When looking at the front of the device, with the charging point at the bottom the device has a hinge clip and wires on the top right.
    • While opening, be extremely careful not to damage the fragile cables and connection between the main body and the faceplate.
    • With a fingernail or some kind of slim pry tool, gently lift from the bottom left corner.
    • There is adhesive that is holding the faceplate on, If you have difficulty pulling it off, use a plastic spudger by inserting it in on the bottom left then slowly hinge the device open while applying pressure to the adhesive pad to loosen it.
    • Normally you'd disconnect the battery first, but with this device we cannot reach the connector until we remove the battery cover.
    • This connector is the same one on the Nintendo Joy-Cons, this connector has no retention clip, and must be pried upward to remove it.
    • Do not pull on the wires directly. They are fragile and will strip out of the connector with too much force, instead using the flat end of your spudger tool, reach under the connector and pry it up.
    • The battery is attached to the cover with some adhesive, use your spudger to carefully and gently lever it off the cover.
结论
David
于08/27/14注册
576 声望
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 23
过去 7 天: 118
过去 30 天: 515
总计 2,165
