跳转到主内容
Pokémon™ GO Plus+ Factory Reset
你所需要的
  1. Pokémon™ GO Plus+ Factory Reset, One Simple Step: 步骤 1 中的图像 1,2 Pokémon™ GO Plus+ Factory Reset, One Simple Step: 步骤 1 中的图像 2,2
    • Press and Hold on the Top Button
    • While still holding the top button, press and hold on the small back button.
    • This button is slightly recessed. You'll likely need to use a paperclip, SIM Eject tool, or other small pinpoint to press this button.
    • Upon pressing and holding the back button you'll feel a short vibration, continue to hold both buttons until you feel a longer vibration which indicates the factory reset is complete. After this you can release all buttons and re-pair it to your device.
结论
2等其他人完成本指南。
David
于08/27/14注册
933 声望
创作了5篇指南
4指南评论
Der Guide war gut, doch fehlte zum Lösen meiner Pairingprobleme noch das Löschen des GO Plus+ in den in-game Einstellungen von Pokémon GO als wichtiger Zusatz.
LordP - 回复
I feel the first vibration but I hold it for like 2 minutes and it doesn’t vibrate again. I am trying to factory reset it because it doesn’t work and I’m trying to see if the factory reset will work
Dreepyaway77 - 回复
Did you fix it?
Christian -
I'm having the same issue, I believe mine is related to the battery not being charged enough to do anything. Not sure how I can get a discharged battery to start charging though.
Michael Mullins -
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 107
过去 30 天: 500
总计 18,541
