简介
This guide shows how to replace a defective touchpad from a Poin2 Chromebook 11.
你所需要的
Power down the Poin2 Chromebook 11 and disconnect the power adapter.
Close the Chromebook and position it with the base facing up.
Use a #0 Phillips screwdriver to unscrew the ten 7mm screws that hold the base to the rest of the frame
Locate the ZIF connector on the touchpad's circuit board.
Use the tip of the spudger to flip the locking flap to the perpendicular position and pull the cable out.
即将完成!
结论
