跳转到主内容
Poin2 Chromebook 11 Speaker Replacement
你所需要的
  1. Poin2 Chromebook 11 Speaker Replacement, Battery: 步骤 1 中的图像 1,2 Poin2 Chromebook 11 Speaker Replacement, Battery: 步骤 1 中的图像 2,2
    • Power down the Poin2 Chromebook 11 and disconnect the power adapter.
    • Close the Chromebook and position it with the base facing up.
    • Use a #0 Phillips screwdriver to unscrew the ten 7mm screws that hold the base to the rest of the frame
    • Poin2 Chromebook 11 does not have screws under its rubber feet at the base.
  2. Poin2 Chromebook 11 Speaker Replacement: 步骤 2 中的图像 1,3 Poin2 Chromebook 11 Speaker Replacement: 步骤 2 中的图像 2,3 Poin2 Chromebook 11 Speaker Replacement: 步骤 2 中的图像 3,3
    • Insert a 1cm-wide plastic opening tool between the base and top frame.
    • Applying pressure up and down with the tool may be necessary. When you hear a "click," this indicates the separation of the frame.
    • Pry (up and down) around the entire border of the Chromebook to separate.
    • Use your hands to gently lift the base away from the frame.
  3. Poin2 Chromebook 11 Speaker Replacement: 步骤 3 中的图像 1,3 Poin2 Chromebook 11 Speaker Replacement: 步骤 3 中的图像 2,3 Poin2 Chromebook 11 Speaker Replacement: 步骤 3 中的图像 3,3
    • Disconnect the white 8-wire battery connector from the motherboard using a spudger to push the two L-shaped clips out of the port.
    • The connector is a tight fit and requires careful pressure for release.
  4. Poin2 Chromebook 11 Speaker Replacement: 步骤 4 中的图像 1,2 Poin2 Chromebook 11 Speaker Replacement: 步骤 4 中的图像 2,2
    • Remove the six 4mm screws using a Phillips #0 screwdriver.
  5. Poin2 Chromebook 11 Speaker Replacement: 步骤 5 中的图像 1,1
    • Lift the battery from the frame.
  6. Poin2 Chromebook 11 Speaker Replacement, Speakers: 步骤 6 中的图像 1,2 Poin2 Chromebook 11 Speaker Replacement, Speakers: 步骤 6 中的图像 2,2
    • Unplug the black speaker cable from the lower, left side of the motherboard.
  7. Poin2 Chromebook 11 Speaker Replacement: 步骤 7 中的图像 1,3 Poin2 Chromebook 11 Speaker Replacement: 步骤 7 中的图像 2,3 Poin2 Chromebook 11 Speaker Replacement: 步骤 7 中的图像 3,3
    • Use the opening tool to pry the two speakers away from the frame.
    • An adhesive strip attaches each speaker to the frame. The speakers should pull away with moderate force.
  8. Poin2 Chromebook 11 Speaker Replacement: 步骤 8 中的图像 1,2 Poin2 Chromebook 11 Speaker Replacement: 步骤 8 中的图像 2,2
    • Detach the speaker cord from the hooks holding it to the frame and lift the speakers away.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 207
